Old 06-16-2014, 12:01 AM
Legless's Avatar
Legless Legless is offline
Cobra Make, Engine: DRB 302 Ford HO Block
If you have an LH front end you could swap the upper control arms for UC’s. The UC’s have an offset ball joint which allows more positive castor. You can also move the upper control arm mounting bolt about 18mm lower and have it in a slightly lower position than was in the A9X.
There is some good information here;
Suspension
Depends what model and what bits you’ve got...
Legless
If its not blown it sucks!
