06-16-2014, 07:25 PM
MO
Cobra Make, Engine: Hurricane - FE
Jet, Corrector, Holder drilling
A number of questions on the practice of drilling jets/holders/correctors
- I have a number of jets I obtained from a friend who has, in the past, drilled jets till he found what he liked, then ordered a set of replacements at that size. The jets he lent me, I don't know if they've been drilled or not. Example is an idle jet market 55F10. But a .60 mm drill will go thru it with just a very slight drag. The drill shank actually measures .565mm. the $1000 question, is the jet actually a 55 or is it a 60?
- Does anyone know the typical undersize amount a drill is from the hole it is supposed to drill. ie, if it is a .60mm drill, what should the bit shank actually measure? I know the drills will drill just slightly larger than the shank, but I don't know how much
- Does everyone agree it is an acceptable practice to drill holders or correctors since they are passing air and not as flow critical as jets?
- Is there a way to definitively tell if a jet has been drilled or not. Obviously, if it is marked 150 and it passes a 170 drill, but what about those that are just a few thousands oversize?
Thanks
Paul
