06-17-2014, 04:08 PM
Cobra Make, Engine: SPF#0760
Alignment, wheel bearings or a warped rotor are other possibilities. You can't swap the front and rear wheels. Tie rod ends, ball joints..... Then spindles.... With braking lessening the wobble that might mean something... But I'm not sure what. Know anyone with another Superformance? You could try swapping the front wheels with them. That would either eliminate or pinpoint the problem component. Oh.. The steering box can be tightened up with an adjusting screw too....
SPFWiringDiagrams@Comcast.net
