Old 06-17-2014, 05:19 PM
DanEC's Avatar
DanEC DanEC is offline
Default Jag rear end play
Bob/others - I noticed that there is a little play in the rear suspension when pulling on the tire at the 6 and 12 o'clock positions (jacked up with suspension at full droop). Jerry rigging a dial indicator to bear on the outside of the rim at the top of the wheel - I get about 70 to 80 thousands of movement rocking the wheel. I haven't played around with it enough to tell if it's axial movement in the half shaft, bearing rock in the outer carrier or a combination of the two. Does that sound pretty much normal?
Thanks
Dan
