You can split the heat sleeve down the length and wrap it over the hydraulic line and use lots of cable ties to secure it. Saves having to disconnect and re-bleed the line. I also put an aluminum sheet as a shield between the brake/clutch lines and headers. My symptoms of hot fluid were a mushy pedal if in stop and go traffic for any length of time.
John
