Old 06-18-2014, 01:55 AM
ha_pe_1968 ha_pe_1968 is offline
Cobra Make, Engine: SPF 2234 Diamond Edition, Roush 427R
Hi Richard!
Had the same problem with my Roush 427R and QFT750. Changing the inital timing, Powervalve and increasing the mainjet was my first way to success. I still have a small lean spot between 1.400 and 1.600 rpm at cruising but think (and hope) i will solve it with the squirters. Have more or less the same sea level like you but different engine, carb size and carb type - so sharing my jetting would not help you. Had an emission test with CO and HC (AFR) that helps a lot.
If you are a member from ÖAMTC you will have access to an emission test.
Greetings from the other end from Austria
Peter
