  #21 (permalink)
Old 06-18-2014, 03:47 PM
JW313 JW313 is offline
Default Ok - here is the news
I did find (surprisingly) several dealer with the Hunter GSP9700 road force balancer. These guys make a killing business here - I guess, the have a patent on that.
Anyways. to make a long story short. I have one wheel in the front, that is completely out of whack. It is vertically unbalanced and uneven - not sure how to call that in English. The outside of the wheel runs ok, but the inside bounces at leas 2-3mm. That of course is worse at 40psi than at 20 psi. The machine likes 40psi to take better measurements. We tried it with wheel only option and wheel an tyre - and the hunter machine threw a big red screen "ALERT ALERT".
We turned the tire about 4 times (each 90 degrees) on the wheel - but with an unbalanced wheel, the effort was hopeless.
How is this possible ? Looks like a brandnew Halibrand knock-off 15inch wheel.
We did what we could and added almost 4 ounces of weights (inside an outside) to bring it to 0 during normal balancing (without the big roll that simulates the road force action).
But the wheels back, brought down the pressure to 21psi and turned the suspension (QA1) down to 4 clicks from loose.
The steering wobble is almost gone. I can still feel it a bit at around 70mph. However, I did not fix the issue but just covered it up with soft setups.
So - road force balancing is a good thing. Helps to see issues that a normal wheel balancer couldnt.
Now, I need a new wheel. I hope, I can still find a wheel with the same color as they made it in 98 . Do you have any ideas where to look for one ?
Thanks guys
Jürgen
