  #22 (permalink)
Old 06-18-2014, 03:52 PM
JW313 JW313 is offline
Originally Posted by Blas View Post
That red bushing in the photo of the AVO below from JW313 does not appear to be standard issue. It looks like the bushing had 2 additional red inserts added to it somewhere in time. Probably due to failure (elongation) of the original bushing. The failure commonly seen on these shocks is the bushing collapsing and the steel ring surrounding the bushing making contact with the A-Arm - leading to a weld or bushing ring failure on the shock and a corner suspension collapse. AVO's shocks on early SPF chassis due date back quite a few years now. The bushings can be replaced if you are so inclined. But since you would need to remove the shocks to replace the bushings and the availability of new ot "take-off" Bilsteins, replacement units make sence. More a matter of age than of bad design anywhere. 12+ years on shocks on a performance car? NO..... 12+ years on a bottle of Scotch? OK.......
This might be an optical illusion - the bright red rubber is the part that was covered up from the washer and the darker one was exposed to the outside. I do believe it is the standard setup.
And yes - I did already touch the A-Arm. Pretty scary stuff, I have to admit, especially since I was on the Autobahn with it bouncing and clonking all over the road ... boy of boy
Laters
Jürgen
