Guess the BHP @ RPM and Torque @ RPM for this crate motor ...
Crate Motor Specs- Torque Plate Honed
- Durabond Performance cam bearings
- Eagle 4340 Steel crankshaft 4.00" stroke
- Callies 4340 Steel H-beam rods 6.300" long
- Clevite Hardened Rod & Main Bearings
- Racetech Forged Pistons with Total Seal Rings
- Compression Ratio: 13.5:1
- Rods (big & small ends) and Pistons machined to same weight
- Rotating assembly balanced to .02 oz/inch or within 2 grams
- Brodix STS Track 1 CNC Ported cylinder heads
- 68cc combustion chambers
- Comp Cams 2.100" & 1.600" SS valves
- Titanium retainers & 10° Locks
- Roller Valve Springs
- 225cc Intake Runners
- ARP Studs and Fasteners
- Comp Cams Mechanical Solid Roller Custom Grind Race Camshaft
- Crower Sever Duty HIPPO Solid Roller Lifters
- Jesel Pro Series Shaft Mounted Roller Rockers
- Jesel Belt Drive Timing Setup
- Comp Magnum Pushrods
- Edelbrock Super Victor Intake w/4500 flange
- Holley 1050 Dominator Carburetor
Fill in the blanks ...
_____ BHP @ _____ RPM
_____ ft/lbs @ _____ RPM
_
