Old 06-25-2014, 07:00 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
I would suggest you take your cable to a local speedometer repair place in Houston and have them make one for you matching the ends and length for an easy replacement. Make sure it has lub in it and install. Cost wise, it should be close to the Ford unit if you can find the right Ford unit.
Bill K
