Thread: Carb Diagnosis
Old 06-25-2014, 08:04 PM
jhirasak's Avatar
jhirasak jhirasak is offline
Cobra Make, Engine: 331 SB, AFR heads
Wayne,
There are a few of other scenarios associated with the Power Valve that I could describe that will all give you the symptoms that you have described. These include a failed spring, sticking valve, partial blockage of the manifold vacuum port, or improper seating of the gasket on the power valve seat. With the information provided thus far, I cannot give you a better guess as the actual cause of your problem.
John
