Ok, so I got the old slave out and the new one in and will start adjusting / bleeding tonight or tomorrow. As I read ERAs manual, I am using a return spring and the throw out bearing should not ride against the pressure plant when the clutch is not depressed. When I push the clutch in, it should be enough to completely engage the clutch. My only concern is can the adjustment rod be pushed so much against the slave that it pushes the piston back to far? Is there a standard amount of travel I should see from the slave cylinder itself?
Phil
