Old 06-27-2014, 05:39 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
Default Clutch Adjustment
Ok, slave cylinder replaced and not leaking. Bled and seems to be working. It goes into gears easily in all gears. The only question I have is I cannot tell if the throwout bearing is resting against the pressure plate fingers, but it appears that it is touching. Should it be? If not, how do I back it off? I have the tunnel in the car removed. Its not a hydraulic clutch throwout bearing. It does not appear that it is pressuring the pressure plate but does appear to be resting on the pressure plate fingers. Advice would be most appreciated.
Phil
