Old 06-27-2014, 05:49 PM
DanEC's Avatar
DanEC DanEC is offline
It takes a fairly good clutch arm return spring to counter the spring inside the slave cylinder. Possibly you need a slightly stronger spring. When pushing the pedal by hand can you feel a bit of movement before it gets stiff from contacting the clutch? If so you are probably OK but you may want to look into a little stronger return spring.
