Phil - I agree that you need a shorter spring. I can just barely see inside my Quicktime bellhousing with a strong light and by having someone lightly push the pedal or by pushing on the throwout fork, I can percieve slight movement of the bearing against the clutch fingers. That's about all I can think of. As long as you have a little take up in the clutch pedal before it gets firm from applying pressure on the clutch, and get a shorter spring, I think you will be OK.
