Old 06-28-2014, 05:05 AM
Dimis's Avatar
Dimis Dimis is offline
Originally Posted by RACERAL View Post
Are they box stock heads... i bet you could sell the heads easy and pick up a set or Blue thunder "worked on heads" from Barry at Survival and hit your mark.
Except for one small wrinkle...
As I understand it, the exhaust ports on a BT won't match up to the headers from an edelbrock.
However there are other options for heads if you're interested in going down that path, and the edelbrocks can even be worked to flow a little more.
Check in with Brent Lykins, I think he may have a set of BBM heads in his sandbox you might want to play with.
