SGR.
Mount your posts and transmissions. (the posts), mount the business end of the motor pointed to the first post. You are going to put a single flare on the first end that screws onto the motor via the included bezel. then with a light bend following the top of the cowl. Now you will see a slot cut into the cover plate of the transmission, this is where your second single flare will fit.
Take the second tube, again bending to follow the cowl, go far enough to put another single flare in the tube just long enough to go from the out board slot of the first tranny to the first slot in the second (Drivers side) tranny.
Finally last tube, one flare to fit into the outside drivers trannys slot about then inches long. Anything left over cut if off and disregard.
Clear as mud-no?
DC
