Old 06-30-2014, 09:27 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Kim, I can help you with that. It is totally adjustable if you have heim joints and contingent on the arms being the right length. Which there has been a problem in the past. By coincidence I am readjusting mine right now. The lower arms set the wheel base and squareness with the frame. The upper arms set the pinion angle and center the axle between the wheel wells or frame. I hope your axle is straight. I had to have Currie straighten mine.
It can be an involved process but you can do it. It would take to long to write it here. Send me a PM with your ph number and we can talk on the phone. I am retired and am available most of the time.
Added: Sent you a PM with my number.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
