Originally Posted by 66gtk
Car finally arrived and the 15" wheel is fine! I have just enough room for me leg between the wheel and the shift lever in first gear, and getting in/out is fine. I'll keep the wheel I have.
Glad it's fine. If you do decide later that you need a bit more thigh room you can see if the steering wheel and column can be shimmed up higher. I have myla ter model ERA in the non-shimmed position but there is room to raise it 1/2 inch or more with shims if I needed to.
