Old 07-01-2014, 08:27 PM
Double Venom's Avatar
Double Venom Double Venom is offline
350 lbs for a small block, Heidts tubulars will get rid of the torsion bars- small welding required. QA1's work fine on the front, Heidts or QA 1 can tell you what shock to get.
The difference for the buck and the little amount of work will leave you speechless with the results.
Actual /true professional testing, ditch the CR's front sway bar!
DV
