Old 07-02-2014, 08:02 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Mr Penn oil,
The HEIDTS control arms are meant to be used without the strut arms.
The CR's sway bar was NEVER designed to work on the Cobra! It was made for a Bronco II.
Way to heavy for a CR's.!
You can - with success- put a sway bar on but it IS LESS than half the thickness of the OEM CR and you have to make it. (I used sway bar material from SPEEDWAY Motors.)
ALL of my suspension suggestions have been 'figured, tested', and driven by Pro's that make their living racing OEM cars.
Personally, I take suspension very seriously.
The DV still holds the fastest track time at Run N Gun after 15 years!
DV
