Thread: Bump Steer
Old 07-07-2014, 01:07 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
I must ask again what year is your car. There were B&B cars built from May 2009 through Jan. 2010 that had defective front suspensions. The lower control arms were located in the wrong place. They were to low at the frame mounting points. This would cause bump steer. I had the problem with mine and fixed it. I got the correct measurements from the previous partner, Barry McGill. I also created a how to fix it MS word document with pictures. This may or may not be your problem.
Before the fix. Notice the lower inside mounting point is at the bottom corner.
This is after the fix with the lower A arms moved up to the correct location on the frame. The upper shock mounting points were also in the wrong place.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
