Old 07-08-2014, 04:07 PM
jhirasak's Avatar
jhirasak jhirasak is offline
Cobra Make, Engine: 331 SB, AFR heads
Paul,
I think that Z and Hyde have a very good point in that you should resolve your idle mixture screw response problem before attempting to iron out the transition roughness issue. Since the idle circuit performance overlaps the main circuit transition region, the idle and off idle mixture control must be corrected first. Otherwise, you will be chasing a number of rabbits that are difficult to catch.
John
