Go to the nearest 1/4 mile drag strip within 100 miles and spend the day making passes. Throw out gizmos, drop tire pressures gradually to the 18 pound range. With your 600+ HP you should run high 10's all day if you can drive. You should 60 FT around 1.2 if you learn how to hook it up.
Chas.
