Old 07-15-2014, 11:08 AM
jhirasak's Avatar
jhirasak jhirasak is offline
Cobra Make, Engine: 331 SB, AFR heads
If you delete the light, I would recommend that you either install an ampmeter or a voltmeter in your charging circuit to provide you with information regarding the status of your battery as well as the performance of your alternator. If you already have one of those on your car, I would consider it appropriate to delete the indicator light.
John
