07-17-2014, 06:16 AM
NH
It's flat sheets of aluminum shaped at the top edge to fit the body with a foam channel over the edge to seal the gap between body and sheet edge. The left side has rollbar rear brace threaded inserts spaced a little wider than Mikes pictures. The right side has a plate welded to the framework behind the sheet that supports the electric fuel pumps. The pumps are only using the inside bolt holes for support or they are too close to each other to even plumb. The panels are poorly masked and mostly sprayed black on the inside. The outside of them has the textured under seal sprayed on.
