Old 07-18-2014, 11:02 PM
BevanWright BevanWright is offline
Cobra Make, Engine: Almac Cobra 427R
I have one of those, in my case it pumps into a surge tank, and is not under pressure.
I believe if you turn the brass screw it will adjust the pressure, but which way and how much I am not sure. Also make sure you clean out the filter in the bit next to the brass screw as it blocked in mine (with old foam from the race tank which has now been replaced).
