Old 07-19-2014, 12:32 AM
CobraSwede CobraSwede is offline
Default Reverse water pump for a 351w from 1974 ?
Hi, I am building a FFR Roadster Mk 3 in My garage. The engine I am going yo use is an 351 Windsor from a 1974 Gran Torino. I bought the engine without any brackets or pullys. The alternator, the waterpump and the hydrobooster pump requires brackets and pullys so I bought a CFR Kit for a Mustang 5.0 that requires a reverse rotation water pump.
As I couldn't find a reverse pump for My 74 engine I try to find other solutions. Two possible solutions are - two separate belt system - or - an electric waterpump.
The two sepate serpentine belt system requires - a dual-belt crank pully and the electric waterpump has to be supported by an extra idler-wheel. Do someone outthere have a better solution or could You recommend where to find the pully and the electric pump ?
