Originally Posted by Stephan427SC
Hi guys,
I want to set the correct A/F ratio or lamda for my engine ( Ford FE390 stroked to 445cui with 48 IDA Webers). I installed a oxygen sensor in exhaust on passenger side.....
I was told to set the A/F ratio while idling at about 14.9....what do you think ?
Is the engine with a 12 A/F ratio too lean ?
Can you get me some more information or tricks ?
Thanks,
Stephan
You won't achieve a satisfactory idle at 14.9:1.
12:1 is rich not lean.
12 parts air, 1 part fuel. Both by weight.
