Here's the specs on my engine:
67 428 block bored .030 over
Stock Crank .010 &.010 w/external balance
Stock rods balanced & ARP bolts
Forged TRW pistons 10.5 :1
Federal Mogal moly rings
Clevite 77 bearings
Edelbrock heads w/.090
oil restrictors
Fel-Pro head gaskets
Crane cam 226/226 duration & .537 lift
Crane hydraulic lifters
Crane 3/8 pushrods
Harland Sharp roller rockers
Cloyes double roller timing chain & gear set
Melling HP/HV
oil pump
Crane 3/8
oil pump drive shaft
Edelbrock heads w/.090 oil restrictors
FPP billet spacers & rocker shaft end stands
Cobra Lemans polished finned aluminum rocker covers
Edelbrock aluminum water pump
Edelbrock Performer RPM aluminum manifold
Holley 4779 750 Double Pumper
Tony Branda finned aluminum 7 qt. COBRA oil pan
Mallory Unilite distributor
Mallory Promaster coil
Mallory Hyfire IV ignition box
Accel wires
Polished timing cover
Polished aluminum power steering pump brackets
Chrome power steering pump
Chome alternator
Chome FE expansion tank
Polished stainless steel mandrel bent radiator tubing
Remote double oil filters
Earl's oil cooler
