Originally Posted by crenbbf
Hi All
Just been measuring up and the figure comes to 8.4-8.5"
Does this sound okay thought they should be around 9"?
The block is not decked although the heads(iron) are more of an unknown quantity.
Cam is a Lunati Voodoo with hydraulic rollers
Turned the motor over two or three times and double checked the measuring but arrive at the same conclusion.
If this turns out to be correct where are the best places to get the 'rods?
I see Crane do an 8.51" 'rod (MGB I believe)
cheers
smith brothers will make up any size you want, any ends you want.
quick turn around too
