Yes. I have done it. I put the spindles from a 98 Cobra on my M2 front end. I had to modify the lower control arm as the M2 balljoint is not at the correct angle for the SN spindle. For the top, I used adapters from a FF. The upper control arm needs to be pretty short to get the spindle to sit correctly. I had installed coilovers as the adapter from the FF would not clear the M2 upper spring perch. Not a bad deal as the spring and shock set-up on the original M2 is pretty old technology anyhow.
