Originally Posted by BAsque1
Hello Rick, Lou (Basque1):
Thanks for the detailed diagnosis.
I am now waiting for the new cap & rotor (MSD)
I do have the MSD coil mounted sideways, I know about these and on the instructions it calls for "it can be mounted sieways) If you deem appropriate I might be able to reinstall it vertically instead.
I will star testing one thing at a time and will report back. It will take more than 2 days I have contractors in my house doing some work the next two days.
Thanks so much
regards
Lou
If you get the MSD 8222 Blaster coil, it can be mounted in any position since it is high vibration epoxy filled.
If you are using an MSD ignition, then I believe you dont need the ballast resistor. The resistor is used with points style ignition.
