  #31 (permalink)
Old 07-25-2014, 12:05 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by genolan View Post
Well it ended up being the primary metering block was full of junk which looked like the finish of the metal was delaminating and pitting. I also found a cracked secondary float that needed to be changed.
good deal....does it run ok now?
BTW, if you use AN yes...but somewhere on a fuel pump or filter, there will be an AN to NPT adapter fitting...in which you will have to seal.....
as you screw in a NPT shards of tape do get peeled off and migrate into the fuel 9 times out of 10 they just pass through and get caught by a filter
but when they get caught some where bad it can be a drivability burden to diagnose.
Fred B
