crenbbf Cren nice work on the head ports. You can see how far out the intake is. I don't know what manifold you are running but having it ported and have the cfm all the same in each cylinder would help. No sure if you want but Joe Craine does this to any FE manifold and gets all the ports within a couple of cfm. Stock manifold can be as far out as 30-40 cfm between ports. I had mine done and so have a couple of others here. Helps the motor. There is a lean cylinder on FE's. Think it's 7 or 8. Joe fixes this. He has done alot of manifolds on the FE forumn.com also. The manifold came back looking too good to but on the motor. Wanted to leave it on the coffee table.
It's a bla ck art to get each cylinder with the same fuel/air. it's just a suggestion. Turn around is 1 week. Cost is low for all the work. Shipping about $65.00 each way. Good luck. I don't have a picture to show of how he shapes the inlet to get each port the same amount of air/fuel, it's custom. Rick L.
