Old 07-27-2014, 05:44 PM
mnm99's Avatar
mnm99 mnm99 is offline
Default Charging system or battery???
I posted this in a couple other forums too. Wondering if you guys can help.
Well this is the second time I went out for a cruise and stopped, went to start and the relay goes click, click click. I'm lost. My charging voltage at the battery is 13.86V when the car is running at idle. I have an MSD6al and a electric fuel pump. Turn the car off and it drops to 12.4. So it looks like the alt is charging. I can take the battery cables off and the car still runs. I clutch started the car to get home with no problems. Now...when I got home I turned the car off and was able to start it once then dead. This is where I'm lost. Last time this happened I went to my local Autozone and had the battery tested. Voltage was good and CCA was around 450 when It should be 560CCA. So I went home and charged the battery over night. Brought it back and had it tested. CCA was now 565 and voltage was good. I was told the battery was good. What am I missing? All connections are tight. If I give the car a jump it starts. I'm charging the battery again and having it tested somewhere else. How can I check the charging system? Or did I do it right?
Notes..It goes click, click, click. Cant start it by bridging the solenoid. Battery ground is solid and tight from battery to chassis and chassis to engine. Terminals are clean and tight. Can start it with a jump
Thanks
Superformance #467, 351W, Supercharged
