The only problem with fix a flat is if you hit something and slash the sidewall. Fix a flat is messy stuff. If you know where the leak is, you could plug it. I'll be getting a skinny space saver tyre, with 2 stud patterns. My front and rear pattern is different. Just make sure your rear tyre fits in the boot [trunk]
JD
