Old 07-28-2014, 12:15 PM
avdcav avdcav is offline
Cobra Make, Engine: Everett Morrison
Axle bearing most likely " Just pop the axle out and check the bearing for wear. This
Is a general maintenance item anyway " 4-5 years and they are junk I just did mine in
March. Just take the axles to a machine shop as they need to be pressed on.
When you pop the axle out really try and jiggle that bearing if it goes up and down pivot
It's junk. Side to side means over the winter.
