Old 07-28-2014, 11:27 AM
Chilibit Chilibit is offline
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
In the first post you said the battery ground was solid and tight. In my case the ring connector on the end of the grounding cable was solid and tight to the frame but the cable was actually broken inside the insulation where the ring connector is fastened to the cable. It was intermittent and not merely a good or bad connection. Changed the cable and it has been good since. In my case it is under the carpet by the left rear tail light assembly.
