Old 07-28-2014, 02:49 PM
mnm99's Avatar
mnm99 mnm99 is offline
Update..I had the battery check and THEY (3people) said it was good.
1- I installed the battery, connected the + and used a test light between the - terminal and wire. NO LIGHT. Turn on the key and LIGHT.
2- Connected my AMP meter between the same leads and read 0. So far no draws.
3- Connected my DC AMP probe around the starter lead and cranked 4 or 5 times with the coil off. Reading was 165A. So far good.
4- Went to start the car and started to get slow at turning over....rrrrrrr...click,click,click...Nothing now.
So it looks like the battery is getting replaced for now. It is rated at 580CCA and I'm getting one that has 700CCA
Superformance #467, 351W, Supercharged
