Old 07-29-2014, 12:59 PM
Barry_R Barry_R is offline
Yep...
Steel gears from Crane here.
.467 shaft for OEM distributors
.500 shaft for Accel, Mallory & some others
.531 shaft for MSD
They are generally marked as "460 and 351C" parts. They fit fine. BUt as Lykins mentioned, there is a specific height that you need to press to. Rotate the shaft 90 degrees from the original location and drill a new hole - the original will never line up correctly.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
