Old 08-05-2014, 08:57 AM
strictlypersonl strictlypersonl is offline
Originally Posted by Gaz64 View Post
Dan,
...You'll find the ring terminal is not large enough in cross sectional area to carry the current draw required. Combined with a loose nut and/or poor crimp to the wire, and the connection overheats.
After about 1000 ERA kits that have worked fine with that eye-ring, I suspect the problem was a bad physical/electrical contact somewhere at or near the ring. For those using high-draw or high-output charging systems, I've occasionally supplied a different feed wire that bypassed the ammeter circuit - the real limiting factor.
