Originally Posted by MOTORHEAD
MSD installation instructions say "do not mount ign box in engine compartment" yet most are mounted there. They also say "do not mount coil to cyl head" yet most are.
Conclusion: Hot rodders can't read !
I have mine in the engine bay away from the engine or heat source without a hitch. here is direct copy from the instruction sheet FYI
MOUNTING
The MSD can be mounted in most positions, except directly upside down (if upside down, moisture or water cannot escape). It can be mounted in the engine compartment as long as it is away from direct engine heat sources. It is not recommended to mount the unit in an enclosed area such as the glovebox. when you find a suitable location to mount the unit, make sure the wires of the ignition reach their connections. Hold the Ignition in place and mark the location of the mounting holes.
•If you have a 6A Ignition, use an 1/8" drill bit to drill the holes. Use the supplied self tapping screws to mount the box.
•If you have a 6AL, 6T, 6BTM, 6-Offroad or "N" Series, use a 3/16" drill bit and drill the holes for the supplied vibration mounts. Install the vibration mounts, then mount the Ignition.
I just recently installed the MSD cap and rotor vs generic and the wires as well. The coil should be mounted in the vertical position.
In the interest of originality I am not sure if MSD has a the black distributor cap.
The picture has not been updated with the new cap .
