Old 08-07-2014, 06:50 PM
lippy lippy is offline
If the threads on your plugs are wet, it's the intake gasket area.
Chas, can you please provide a bit more detail on this? Do you mean that a leaking intake gasket leaks inside the cylinders and wets the plugs with oil? If the plugs are wet with oil, how would you know if its the rings, seals, or intake gasket? Or are you referring to the plug valley at the outside, which I would think would be the valve cover gasket? Thanks.
