Old 08-07-2014, 07:26 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
Matt,
Whatever you do you should cut out the CR mufflers. Look at them to see how restrictive they are. Then Throw them away or make some yard art out of them. I did and went with Classic Chambered and ceramic coated.
If you want the chrome look those stainless steel pipes look and sound great. They will never peel or flake like I have seen some chrome pipes do.
The CR exhaust is slightly longer but also only 3" diameter compared to all others which are 3 1/2"- 4" diameter. The Classic Chambered mufflers come with 2 1/2" inside opening or 3" inside opening. I opted for the 2 1/2" and faced the little louvers inside so the open end of the louvers was facing the exit end of the pipe. Tickled my insides the first time I fired it up. Not to mention a big jump in power output proven on the dyno. You will need to do some tuning to get your A/F corrected.
John
