  #139 (permalink)
Old 08-13-2014, 08:21 AM
Hail427's Avatar
Hail427 Hail427 is offline
Cobra Make, Engine: Pace 427CC 3UZ FE V8
Originally Posted by Buzz View Post
Hail - if you use a trapdoor into the airbox from the shroud opening, do you think that using the hot air passing through the radiator for intake might cost you some horsepower as opposed to drawing cooler air from somewhere else?
Also, not too sure about the pressure there, as the design by nature is intended to create a low-pressure zone above and in the hood opening to assist in drawing air through the radiator and evacuating up and over the bonnet.
Thanks Buzz, I haven't tested any venting yet but there is so much room up front I think the heat would be minimal.
Again I haven't tested but I will see where the best placement of air box and use of the air pick up would be, thank you for your thoughts I assumed every thing was going from the shroud but if it could be made simpler it always the best way (KISS)
parts pile until the first start then it is a car
