08-13-2014, 07:04 PM
CA
Cobra Make, Engine: Early Contemporary 427SC w/ '66 427s.o. (car built in '79) by Snow White Rods (Fresno, CA); XKE Series II front/rear suspension (AMP lower A-arms/half shafts), CWI rebuilt IRS, 4-spd Toploader, PS Engineering knock-off rims.
Neutral
Originally Posted by mickmate
Make sure your shifter is set with alignment pin and is getting full throw. That's just a hopeful check, I found it was bad sychro rings with the same symptoms.
I agree with MickMate - you might have bad synchro rings...saw that same symptom in my Toploader...George
George
