Old 08-15-2014, 07:01 PM
blykins blykins is offline
Well, I got a good bit accomplished today. Heads are assembled and ready to go. Crank is in, cam is in and degreed, and got 4 pistons/rods knocked in. Rod side clearance was too tight, so I had to drop the other 4 rods off to have them surface ground.
Anyway, pics....
Install height was 1.800-1.810". Springs came in at 145 lbs seat, 375 lbs open at that install height. Camshaft was degreed, crank gear stuck on 2 deg advance keyway, ICL was 105.5 degrees, 112 LSA.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
