The car is going together very well, after 2 weeks and about 30 hours I have a pretty good start on it. All the wiring is in and hooked up, weather stripping is on,the dash and column are installed, MSD box mounted and wiper motor and assembly installed. I lizard skinned the entire interior including the trunk and added some dynamat to the foot boxes. I have to give credit to ERA, every where you think a clamp should be for the wiring or battery cables they have a hole pre-drilled and in most cases the clamp already installed.
