Old 08-20-2014, 08:57 AM
tcabece427's Avatar
tcabece427 tcabece427 is offline
Cobra Make, Engine: ERA
I assume the voltage regulator is separate from the alternator? If the it checks out ok by Advanced Auto then it is probably the regulator. The other thing could be if you have underdrive pulleys? It's less likely because it seems to charge at idle? Without the Fan and Headlights on.
